the heated steering wheel is switched on by the seat. separate operation is not provided by the factory
Beiträge von booch
activate in ddt4all 4 chennals and do not open the radio
Ich spreche von dem auf dem Flügel
Kann mir jemand die Teilenummer für den Blinker sagen Facelift?
the lower unit can be buy, but it is responsible for the operation of the main light and not the DRL. Another control unit that is not for sale is responsible for the DRL
Alles anzeigen
If you believe that the main headlight control unit at the headlight bottom is damaged, this could be easily replaced. Spare parts are available from Renault or Online shops. Smart does not sell them.
Since left and right are the same, the first step would be to swap left and right control units to see if the malfunction follows.Also you could swap entire left and right headlight unit just for troubleshooting (not for driving around).
If you have electronic test equipment like a regulated 12 V / 3 A DC power supply with ampere meter, you could check and compare the current consumption of the turn indicators.
only DRL is not controlled by this unit. There are three blocks on the headlight
hello,
I replaced the side blinkers by non original LEDs.Really? So what should I do?
given that the control unit will not be sold separately from the headlight, then either look for a broken one or buy a new one
Alles anzeigen
Hello Plontine,
I hope you are doing well.So finally, I replaced my side blinkers by LED.
I noticed that the problem is still here but appears after around 20 minutes of hazard lights on.
Before replacement, it was appearing after 2-3 min. So it’s better but still here.
Just to let you know.
I think maybe that I should replace the rear lights to full led. Maybe it will solve completely the issue.
Thank you,David
Tell me what number of the side turn signal or did you replace it with a non-original one?
problems with the right headlamp, this is a factory defect of production. I have already met 4 headlights and all the right ones that had problems with the turn signal and not one left.
